Replacing Navien Three way valve
Big Ed_4
Member Posts: 3,246
I have two to replace , Came across two within the same day , for the first time . Hot water no heat . I could not purge water though supply . Black and Red have voltage , black and the other color does not ...
I have the valves , extra gaskets for behind the circulator and plenty of seals for connections , with plumbers grease .
Any tips or tools needed to replace would be appreciated
Look Like I will find out...
board has to come out. circulator has to come out. then you can remove 3way. need about 6 o rings. as well as plumbers grease. don't rip the o rings. im probably doing one of these this week. pro tip. buy magnetic screw drivers.
I installed my first today , I know now if there is no union between the 3 way and supply pipe cut it out and you will need to install one . The 4 small screws under the cabinet holding the valve , need a straight alignment to remove . To make a short story long it sucked . Give me Bosch
ya im kinda hoping i can undo the screws. and spin it out inside cabinet.Big Ed_4 said:I installed my first today , I know now if there is no union between the 3 way and supply pipe cut it out and you will need to install one . The 4 small screws under the cabinet holding the valve , need a straight alignment to remove . To make a short story long it sucked . Give me Bosch
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 998 Plumbing
- 391 Solar
- 55 Water Quality
