Ultra vent pipe
kubota
kubota Member Posts: 3
edited October 2020 in THE MAIN WALL
What do you Use in place of ultra vent pipe have a older furnace but the flue pipe is 4 inch ultra vent pipe that was discontinued ? Did they make a replacement ? Would like to know.
  • kcopp
    kcopp Member Posts: 4,576
    It depends on the appliance.
    What is the make and model?
    They did have some serious issue w/ that plastic venting. I am 99.9% sure it had a recall.
  • JUGHNE
    JUGHNE Member Posts: 11,447
    It had a recall years ago. SS piping was furnished and labor paid to replace it.
    I did my own boiler maybe 15 years ago.
    The recall ship may have sailed by now.
  • kubota
    Is ss pipe stainless steel it is made by consolidated Quattro furnace it has 4in ultra vent no one can tell what to use to replace it
    EdTheHeaterMan Member Posts: 10,677
    edited October 2020
    For a furnace, the Corrective Action Program (CAP) offered at no charge to the consumer a power vent and B-vent.  For a boiler there was AL-29 stainless steel vent pipe.   You are describing a furnace, that means your heater is connected to duct-work.  If your heater is connected to pipes with water in them you have a boiler.
    The CAP is long gone and your vent pipe is well past its useful life. The replacement vent design could cost you up to 1/2 of the cost of replacing the furnace.   If you have a boiler then the Stainless steel  vent is still a good option if the rest of the boiler components are sound.
    This is the most recent consumer product safety commission CPSC bulletin in the vent pipe you have
    https://www.cpsc.gov/Recalls/2009/cpsc-manufacturers-announce-changes-to-1998-recall-program-to-replace-dangerous-home
    hot_rod Member Posts: 25,266
    Z-Flex still offers the stainless that was used as a replacement. I think if the product is certified to the Class of venting the appliance required you are covered.
    Probably no one wants to make a recommendation for liability concerns.
    The "starter " piece that connect may be the hard to source part.
    I suspect the Polypro products may work also, a bit more user friendly to install.
    https://www.z-flex.com/productcart/pc/viewCategories.asp?idCategory=555
  • kubota
    Thank you for the info
