Leaking hot water boiler
Hello to all,
I've attached a picture of a ten year old hot water boiler that's leaking. The picture is from the bottom of the heat exchanger. Is there any way to fix the leak?
Thank you, Michael.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    Have a look at the manufacturers installation manual, and see what sort of joint is there between the sections, ie. rubber gaskets, or tapered metal spuds.
    That will give you an indication of what parts will be needed in the repair.--NBC
  • Ironman
    Ironman Member Posts: 7,721
    What's the make and model of the boiler?
    Bob Boan
    HVACNUT Member Posts: 6,792
    Most residential cast iron blocks are 30 year warranty for water. I think 15 for steam?
    Worth checking.
  • charliechicago
    charliechicago Member Posts: 168
    Thanks for the responses.
    NBC, I will look into that. But once I found that out, what's the process? The sections have to be separated and fixed; meaning taking the whole boiler apart?
    Ironman, It's a Unica boiler. Model MGB125HD Serial UEH14043
    Thank you. Michael.
