Chattering
Hi, can someone help. Honeywell VR 8300 gas valve on boiler (burnham boiler) is chattering. Is it something to be concerned about? I know it’s the gas valve because when I pull off the wire from TH or TR the noise stops, I take the wire off it goes away. Is it a safety issue? Do I need to change it? Thanks
  • Ironman
    Ironman Member Posts: 7,858
    How do you know it's not the ignition control causing it?
    Bob Boan
  • mulleralan
    mulleralan Member Posts: 3
    It’s a standing pilot type boiler
    EBEBRATT-Ed Member Posts: 19,599
    Chattering is usually a bad connection or low voltage. It also could be the gas valve or whatever controls it.
    Get it fixed or something will fail
  • mulleralan
    Ok thank you.
