Remote Thermostat Recommendations
Brent H.
Member Posts: 169
Greetings,
Looking for recommendations for a remote/wireless thermostat that will be used in a sunroom. Due to the construction of the sunroom, there is no simple way to run thermostat wire so I’m hoping there is some sort. of wireless option with a controller that ties to the zone controller in the basement.
Thanks.
Brent
Thanks.
Brent
That's wireless?SuperTech said:Honeywell Vision Pro 8000.
@Brent H.
Honeywell Prestige with EIM controller. You'll just need a power supply in the room with the thermostat head. Everything else is done wirelessly.
Vision pro 8000 can be wired in the mechanical room and use a battery powered remote sensor for temperature sensing.0
- 50 Industry Classes
