Remote Thermostat Recommendations
Greetings,
Looking for recommendations for a remote/wireless thermostat that will be used in a sunroom. Due to the construction of the sunroom, there is no simple way to run thermostat wire so I’m hoping there is some sort. of wireless option with a controller that ties to the zone controller in the basement.
Thanks.
Brent
  • SuperTech
    SuperTech Posts: 2,670
    Honeywell Vision Pro 8000.
    STEVEusaPA
  • ChrisJ
    ChrisJ Posts: 17,722
    That's wireless?
    @Brent H.
    Honeywell Prestige with EIM controller. You'll just need a power supply in the room with the thermostat head. Everything else is done wirelessly.
  • SuperTech
    Vision pro 8000 can be wired in the mechanical room and use a battery powered remote sensor for temperature sensing.
