Install a water filter
lmanc2222
lmanc2222 Member Posts: 13
Wouldn’t it be advisable to install an inline water filter to the cold water supply on my 47-2? Sounds to me like a no brainer to help reduce any sediment entering the auto feed. Anybody?
    EdTheHeaterMan Member Posts: 11,753
    IT WON'T HURT. But it will not remove ALL the things that end up clogging the float chamber. If your reason for installing the filter is to eliminate the need for flushing the 47-2, then forget the filter. You are still going the flush weekly as recommended by the manufacturer.
