Weil Mclain LGB-8 Error Lights
dooododoo
dooododoo Member Posts: 25
edited October 2020 in THE MAIN WALL
Hi all, if anyone could help, it would be great.
On this Weil McLain LGB-8, I get 2 error codes:
On for 4 seconds and 3 blinks
On for 4 seconds and 2 blinks
And it then it repeats.
This happens after turning on the unit... I hear some clicks, the burners turn on, and then 5-10 seconds later, it shuts off. The pilot light looks good.
I’ve included the troubleshooting sticker. Can anyone tell me what the error code is saying?
  • JUGHNE
    JUGHNE Member Posts: 11,548
    First and easy and free is to clean the flame rod/sensor.
    dooododoo
  • dooododoo
    Thanks for the suggestion. It was not the problem.
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,315
    I've had a similiar problem in the past. The burner that has the flame sensor for the 2nd stage may not be lighting properly. Sequence of events is: Pilot lights, signal good, light main burners on low, tries to go to high fire, but flame sensor does not sense flame, gas shuts down. I have often had small spiders building webs in the gas orifices, restricting or blocking gas flow to a burner. Since the flame sensor burner all the way to the side, its easy to miss if it is not lite.
  • ch4man
    ch4man Member Posts: 298
    an S8610U is a replacement module, maybe try the OEM.
    those black box Honeywell's are less than desirable
  • ch4man
    PS, Honeywell's must have a good burner ground
