Is this pump sound a concern in your opinion?
SweatyInToronto
SweatyInToronto Member Posts: 75
edited October 2020 in THE MAIN WALL
It's an Armstrong S45 with the NON maintenance free bearings. They were oiled but perhaps not enough at one time.
Mp4 Video + Sound: https://drive.google.com/file/d/1OwfRPljHMAqhjspXn7iQC2e1JLi1D0q4/view?usp=sharing
Mp3 Sound only: https://drive.google.com/file/d/1FmoXmP1iBCjD8OPciH7CCLBiwRgXj1zQ/view?usp=sharing
Note, sound volume increase/decrease due to moving closer and further away...
Thanks much...
  • SweatyInToronto
    Bump
  • leonz
    leonz Member Posts: 1,761
    It needs to be repaired. If that circulator is a B+G unit you should have no trouble obtaining parts.
  • SweatyInToronto
    Armstrong s45.
    Started to replace the bearing assembly. However one or both screw type pump isolation valves failed. So now have to either freeze to replace everything or drain, refill, bleed which is a B. Or let it ride....
    Think it's the bearing or coupling maybe?
