Help with old Capitol Gas boiler
My father has a capitol gas boiler in his house and from the best he can tell it is from the 1940's
It is leaking water into the coupling area I believe its called . Where you would normally pull a amall square cover to oil the area.
I have helped him work on this many years ago.
But not sure what would be involved exactly with the fix. There appears to be a flange gasket but I assume there is also a round seal around the shaft or maybe just packing that needs replacing.
Any advice or direction for parts would be great.
    mattmia2 Member Posts: 14,430
    Some pictures further back would help. That pump could probably be repaired, but it also probably would be inexpensive to replace if we knew what the system was like it was moving water through. There is a shaft seal there, probably flange gaskets but we can't see the flanges in the picture.
    Steamhead Member Posts: 18,027
    @BigJack , where is this located?
    Consulting
  • Big Ed_4
    Big Ed_4 Member Posts: 3,290
    Bearing seal is leaking . Need a new bearing assembly . Looks like a small B&G 100 or Armstrong . The parts are interchangeable .
