Firomatic Switch?
SuperTech
Member Posts: 2,649
I did a boiler maintenance call in a very old home when I spotted this. I guess its some sort of Firomatic safety switch? It appears to have the same handle as the oil line valves. I've never seen one of these in any other house, but then again this house was very old. Likely the 1800s or turn of the century at the latest. The beams in the basement have bark on a lot of them.
Well we can agree it’s not original.
I’ve seen it before. Can’t tell if it’s not that old or very old
Around here it's rare to see one on a residential job. Don’t think Fire Marshals or building inspectors even know what they are.
Btw, what’s this mess?
Edit: fixed some typos.
Every oil fired boiler in Massachusetts has (or had ) one of those . It is a Firomatic switch.
In MA 3 switches are requires. A Firomatic switch on the ceiling (maybe more than one if the ceiling is very high), an "oil burner emergency switch" with a red plate located 'outside the boiler room) and a service switch at the boiler or furnace.
They have been required for years, probably since the 20s.
Now MA gave up there oil burner code and adopted NFPA 3 about 4-5 years ago so I don't know what is required now1 -
Looks similar to the safety device in this post(different form but I assume same function):
https://forum.heatinghelp.com/discussion/180821/help-with-a-new-to-me-oil-fired-steam-system#latest1 -
These were required on most oil supply and return lines for the burners on the schools and hospital boilers that we installed and serviced in Pennsylvania. That type was used on the smaller installations and a different type that looked similar to a ball valve was installed on the larger installations.1
I sure hope they weren't on the return oil lines. Besides being against code, sure fire way to blow a pump seal if (when) they failed.retiredguy said:These were required on most oil supply and return lines for the burners on the schools and hospital boilers that we installed and serviced in Pennsylvania. That type was used on the smaller installations and a different type that looked similar to a ball valve was installed on the larger installations.
@STEVEusaPA You are correct, my mistake. Check valves are required on the return lines.0
IIRC, Checks aren't allowed in returns either. Checks and valves aren't a good idea, for the same reason.
I figured it was something that is code in another area, like @EBEBRATT-Ed mentioned. In my area, The Mid Hudson Valley NY, we are required to have a Firomatic valve on the oil supply line as well as red oil burner switches at the entrance to the basement.
@STEVEusaPA that mess is a leaking and improperly installed air scoop. Homeowners didn't want it repaired because "its been working great that way for years".2
- 116 Geothermal
