Gas Burners
kenny711
kenny711 Member Posts: 1
I am planning having a Buderus G115 installed. If I select a gas burner for it (it will accept oil or gas), what would be the advantages and disadvantages over picking an oil burner?
    Steamhead Member Posts: 18,410
    That boiler will run nicely when the proper burner is installed. You need to see that the burner is matched to the boiler, be it oil or gas- it won't run well with the wrong one. I usually see Carlin EZ-Gas or Riello gas burners on these units.
    Basically, it comes down to which fuel you want to use. If natural gas is available, most people go that way.
    Consulting
