Amtrol WH7L no hot water
Jerredm
Member Posts: 1
Hey, so to preface all of this, I’m not really educated in any sort of heating. My wife and I bought a house about 6 months ago, and everything has been fine. We could run two showers at once, nice hot water. Yesterday, seemingly out of the blue, the water was like warm, and then just cold.
I was trying to look for possible fixes. I tried just simply resetting it from the panel which obviously did nothing, but hey, it was worth a shot. So I’m seeing a lot of people running into issues and fixing it by replacing the smart controller, but mine isn’t humming, or displaying any errors. It’s just cold water.
So I was going to maybe just try to put a new smart controller on it, but I wanted to get some opinions before I spent the money. (I also heard that if you call Amtrol they might replace it for free? So I’m probably gonna give that a shot first)
any help would be great!
The Amtrol tanks had a higher than normal failure rate. Usually the coil would develop pinholes, but increased boiler pressure would often discharge the boiler relief valve. You may want to consider replacing with a stainless steel indirect. If the tank is still under warranty, try Amtrol first.0
This is just an indirect water heater, no?
On a call for DHW, a zone valve opens or a pump turns on and the boiler circulates water to heat the water in the tank. Something in that circuit is not working and it should be relatively easy to find and repair.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
Bluntly, I was never a fan of Amtrol BoilerMate's. If you have a mixing valve on it and sensor, look there. The question is--is the water in the tank hot and what temp?0
Did you set up an oil account or forget to pay the gas bill? Turn up a there and see
If the heat works.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
