Purging a system with a buffer tank
Hello -
I am pretty much trying to build the system shown in figure 6-1b in Idronics 17, minus the indirect water heater.
Caleffi also has a similar design in the documentation for their storage tanks.
My question is, how the heck do you purge the primary pump and furnace? It seems like there needs to be a purge valve between the air separator and the buffer tank, no?
  • STEVEusaPA
    Most buffer tanks and indirects put a vent out of the top. But like anything else, purge it thru the entire system.
  • Ironman
    Ironman Member Posts: 7,903
    edited September 2020
    If you’ll notice, the tank has a vent in the top in the diagram as Steve said.
    There’s also an MBR in the supply line from the boiler to the tank, and most mod/cons have a vent incorporated in them.
    Bob Boan
  • I'm not too worried about the tank, I can see how that will get vented. As you fill from the feeder, the tank will fill up and vent out the top of the tank, but once the tank filled, it seems like it will get 'stuck' trying to get water into the furnace, as both the supply and return lines will see water pressure and it won't circulate to get the air trapped in the furnace and pump. I can see how a vent in the mod/con would help, though.
  • SuperTech
    SuperTech Member Posts: 2,661
    That diagram shows a microbubble resorber that would take care of venting the air in that part of the system.
  • OK, so you won't really get high-flow through that part of the system, the water will just come into the furnace supply and return lines and vent out the MBR.
  • Ironman
    I've never seen a system piped exactly as it was drawn. Drawings are conceptual. I would not put a boiler over a buffer tank unless the tank was small. The orientation of your piping will determine where vents and purge valves need to be located.
    Bob Boan
  • Here's a simplified drawing of how we valve our systems for purging. Close valves A and B, connect a hose to the hose bibb and open the bypass on the left. It purges everything: boiler, buffer tank and the radiant loops.
  • Thank you Alan, your drawing makes sense to me. I can see how the water would be forced to flow through the boiler, into the tank, then through the distribution network before going out. Thank you everyone.
