Type "W" Oil Burner Nozzle
Has anyone been using all purpose Type "W" Delavan oil burner nozzles instead of "A" and "B" and if yes has there been problems ? It would be nice to cut down on the Nozzles we need to stock on our trucks.
Thanks for any input on this.
Jay
  • SuperTech
    SuperTech Member Posts: 2,654
    Unfortunately there's no way to cut down on the need for a wide variety of all three types of nozzles.  Its best to stick with the spray pattern that the boiler is designed for.
    I've used W nozzles in place of A and B nozzles when I'm in a jam.  But i I always make sure I have a true zero smoke and my combustion analysis meets the manufacturer's specifications. And I always go back to the correct nozzle next chance I I get.
    STEVEusaPA
  • Big Ed_4
    Big Ed_4 Member Posts: 3,515
    I only use W nozzles ,B's if I ran out of W's . In my area with corn oil added , the W works the best ...The angle depends on the Boiler and burner . I stay what the manufacture posted on a tuned boilers like a Buderus ... Pin boiler , I prefer to dropping size and increasing pump pressure to stay in the firing range , to get that bright clean fire ...
    JOutterbridge
    HVACNUT Member Posts: 7,410
    Beckett, Riello, and Carlin all have OEM spec books or downloads for numerous burner and boiler combinations. The W nozzle is not all purpose. Its specific to the application. I have been known to use one when I wasn't getting good numbers with a spec'd A or B. Sometimes you need to do a field bench test. I did work with a guy who used a W on everything. He also put a Carlin EZ-1 head on a 99 CRD once, on an original Blue Ray, so there's that.
    STEVEusaPARobert O'Brien
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,588
    Corn oil??
  • Robert O'Brien
    This. The more an OEM spec is different from the retrofit spec, the more likely you'll be giving your analyzer a workout.
    Steamhead Member Posts: 18,404
    Here are some links to Delavan's nozzle literature.
    This one actually diagrams the various spray patterns:
    https://assets.delavan.com/delavan-oil-burner-nozzles-and-accessories.84l1k9.pdf
    This one goes into a bit more detail:
    https://assets.delavan.com/241863-delavancx3.i6jp2a.pdf
    I'm not sure why Delavan calls the W an all-purpose spray. Either the nozzle spray pattern matches the air pattern of that particular burner in that particular boiler, or not. If not, you won't be able to tune the burner properly.
    Consulting
  • Jay_insula1203
    Jay_insula1203 Member Posts: 22
    Thanks everyone for your input on W Nozzles - Jay
