long threads on one inch nipple for pigtail
bluesman54
Member Posts: 2
I guess what I am asking is what is the long threads on this nipple called. It is connected to our steam boiler pressure control.The threads leak steam . We need a gasket but what kind.... very vague ;I know , but at this facility ,I can't send pictures.
Is it a tapered thread? A straight thread wont seal without a few wraps of teflon tape and even then it might be iffy.
Use teflon tape and or pipe compound, that should fix any minor steam leaks.
3PSI gauge0 -
I was just informed it is called an adjustable nipple. I did send a pic but I don't see it here.Thanks.0
That sounds like a nipple from an H B Smith Boiler. Try to send another picture.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
