How To Straighten Bent Ball Valve Handle
Had a new water main put in last year. Installer put two ball valves in, one close to where pipe enters house (main valve) and a backup one after the meter. He intentionally bent the handle probably to allow initial threaded installation, but recently another plumber came for other work and found he couldn't use the secondary valve since the bent handle would have hit the line. I had thought using two sets of pliars--one as an anchor and the other to bend might easily work, but there's a risk of stressing the pipe. I also wondered if that nut could be loosened without affecting the valve so I could remove the handle, re-bend then put back. But don't know if loosening nut also loosens valve itself. I paid for the extra valve so want it to work; could easily call back original installer if need be.
1
I just did the same work at my house and most places the extra valve isn't extra, it's required to allow easy replacement of the meter.
The nut comes off and then the handle can be removed. Sometimes you may need to rock the handle a little.
I'm confused as to why he bent the handle instead of just removing it like most would do. The handle can also be flipped to swing different.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Thanks all. @ChrisJ From right to left (house side towards street); first you'll see shot of old working gate valve that can be used to keep house water up in the pipes when working on something below; then original post showing bent handle, then meter, then after meter and incoming line. There is a hard-to-see ball valve at the incoming wall. I'd wanted a caleffi PRV and pressure gauges before and after meter but contractor was old school didn't want those bells and whistles.
I took off the top nut and tried to flip it two ways, over and also tried putting handle on the left, but first way the stop no longer is in correct position so valve could keep turning and turning. handle is HARD to bend back.
Having looked at this, the real problem is that the way it is now, the handle will hit the pipe on its way to off; if I straighten the handle, it will hit the wood support. If I flip handle to the left, it will hit the PRV to valve's left. I think I have to get the installer back to turn the whole valve more. Or can I just buy a short valve handle? Since existing handle looks like brass guess I'll have to get like material.
How often will you use it?
Remove the handle and use a small crescent or open end wrench to turn it, when needed.
The shorty handles can be hard to turn by hand if they are not exercised occasionally.
Cut it down like @GroundUp mentioned slip a piece of heat shrink tube over it and mold a new handle.Bob "hot rod" Rohr
Living the hydronic dream1 -
If it makes you feel any better I have a ball valve on my wet return on my steam system. It's by the floor in a bad spot which I regret putting it but since 2011 my self and a few others have kicked it and tripped over it. The handle has been bent several times on the valve and it's still fine.
@ChrisJ yes, I always come out of Wall threads learning a bit more, though in the scheme of things this is no biggie. I did notice when I first flipped it in such a way that it was without the stops the valve kept turning, and one wouldn't know how open or closed it was unless you tested it with a faucet. Luckily I reversed my motion and got back to default as far as I know.
Another takeaway is the reminder to exercise my heating system and domestic system valves once a year or so.
With the new water main, metal particles no longer collect in the bottom of the toilets.0 -
I have had this problem a couple of times.
First you can straighten the handle in place,
then slip the plastic cover off the handle, maybe heat with hair dryer.
Remove the handle with that nut.
Cut the handle short enough with a bolt cutters or hack saw, in a vice.
Then I would round the corners on a grinder wheel to match the part cut off, shorten the plastic sleeve with scissors as needed and slip back on.
A short piece of PVC pipe gives you a handle extension for that first hard movement, after that no problem.
Or a crescent wrench on the handle at the nut end.1 -
I've done that a few times, @JUGHNE . I like to put at least a stub of the handle back on, so i can see at a glance whether the dang thing is open or closed...Br. Jamie, osb
Not sure about that @SuperTech, those Watts folks usually weld those things on....don't want to start a three-week thread on that one...1
- 15.8K Strictly Steam
