Staple Help- Omega Plates
clementine
Member Posts: 6
Hi there-
Looking for some advice on type of staples and stapler to use with “sandwich method” hydronic install heat plates. The omega plates I am using are a bit thick and I’ve been struggling to sink anything but a 1/4” staple through them. I’ve read 5/8” is best. (I can actually easily pull the plates up off the plywood with the 1/4”- trying to avoid any movement/noise). I’ve read some people using a pneumatic stapler- perhaps longer staples sink flat with this?
Any advice appreciated!
What is going over the plates? The next layer will pinch the plates tight. Ideally the plates touch the upper layer, any “proud” staples will limit a good contact to the flooring.Bob "hot rod" Rohr
hot_rod said:
Pex-al-Pex 1/2” then QuietWalk underlayment- engineered floating floors on top.What is going over the plates? The next layer will pinch the plates tight. Ideally the plates touch the upper layer, any “proud” staples will limit a good contact to the flooring.Yes, trying to get the staples as flush as possible. Only had luck doing this with a basic electric stapler and 1/4” staples. Was hoping to use a longer staple, but lots of trial and error and can’t seem to get anything longer to sink into the plate and plywood. Tried 2 different electric staplers and some handhelds.0 -
The thick plates take a pretty robust pneumatic stapler to get a good length and sink depth. The type they assemble pallets with. Maybe rent one for the job.
A roofing nail gun has enough oomph to drive thru most plates, even the heavy extruded ones from Radiant in Bozeman. Roofing nailers are usually rentable at the box stores.
Just enough fasteners to keep them put, the next layer is more important for keeping them tight.Bob "hot rod" Rohr
I’ll try that. Thanks for the help!!hot_rod said:The thick plates take a pretty robust pneumatic stapler to get a good length and sink depth. The type they assemble pallets with. Maybe rent one for the job. A roofing nail gun has enough oomph to drive thru most plates, even the heavy extruded ones from Radiant in Bozeman. Roofing nailers are usually rentable at the box stores. Just enough fasteners to keep them put, the next layer is more important for keeping them tight.0
