Denver Water to raise ph
hot_rod
Member Posts: 27,344
Anybody seeing problems with this increase? seems it is a bit above what the boiler and indirect tank manufacturers reccomend.
A couple specs from HTP for tanks and boilers attached.
https://denverwatertap.org/2020/03/09/denver-water-increasing-ph-of-the-water-it-delivers/
I wouldn't be concerned. I run from 9-10. I think the manufacturers are a little conservative on the target PH because they don't want frothing/surging that could result in return service calls for installers/service companies. But if you watch your boiler I think you'll see it's fine below nine.
edit: mine's a steam boiler...sorry I get a little steam tunnel vision. Others will comment on other applications
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 123 Chimneys & Flues
