System Idle
Petpluto
Member Posts: 2
My radiant system has been idle for at least 3 years, and hardly used before.
I turned it on for 3 months so I know it works, but lack of insulation and high bills made me turn it off.
My question is how much damage am I doing NOT running the system? (Valves, sensors, pumps )
Some day I will finish insulating and want to use it, but I needed a break.
Provided it's full of water, and that water is adequately protected or at least was when it was added, probably not that much damage to the piping.
However.
Anything which needs to move now and then, such as valves or pumps, should be exercised at least once a month. Otherwise, they tend to become balky when you want them. Or not work at all...Br. Jamie, osb
You should have it checked out, make sure it's full of water.
Also, there are many boiler controls, and circulators, that will automatically exercise when idle for extended periods.There was an error rendering this rich post.
Forgot to add to mine -- if it's not full of water, check it for leaks... and fill it.Br. Jamie, osb
Thank you Jamie and Steve.
I’ll reopen the makeup water valve and hopefully no running water.
it was full when I shut down.0
