Existing Return Sizes a Problem?
swellman
Member Posts: 31
I’ve been working (I think) toward zoning with two circulators. I was reading a bit on primary-secondary piping and am a little concerned having seen this image in connection with a ‘do not’
It’s an existing system so the pipes currently for the return look like this (and I’ve tried to label the pipes based on the Zone they would end up being a part of based on the re-piping I have planned for the supply with the two circulators.
Is it true this looks problematic? My boiler has to take a 1 1/4” return line and I can’t do much about the original line sizes running through much of my house. Should I boycott zoning with circulators at this point?
Blah. So new at this. You guys have been so excellent answering daily to help!
The "don't do this" diagram you have there is not primary secondary. With a high head resistance boiler as shown in the diagram, you should not pipe them that way but in a P/S fashion instead. If you have a low head resistance boiler, piping it that way is just fine. There is absolutely nothing wrong with zoning by circ, it just needs to be done properly is all0
