Radiant subfloor panel choice
What type of room, what’s the floor finish?
Sounds like you biggest issue is availability. I like the Roth panel if it is available near you. I think it comes out of upstate NY.Bob "hot rod" Rohr
We used Ecowarm recently on a small job in Berkeley. I like that you order from them directly, they had everything in stock and shipped quickly. I also like that you can use 1/2" PEX instead of anything smaller so you don't end up with a lot of loops. I believe they are in Oregon.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I have not used a lot of the premade panels, but in my limited experience with them they all suck and are far too expensive for what they are. I prefer to rip 3/4" plywood into strips and glue/screw them to the subfloor then drop transfer plates in the valleys and stomp 1/2" tubing into it. The performance is on par with any premade panel but 1/4 the price, although it does take quite a bit longer.0
I use climate panel all the time, never once had a problem with availability. Great product. Viega and Uponor same product0
At 100$/ hr per person, the client doesn't really want us to be fabricating anything. I know the panel s are expensive, but a) as a plumber I'm not allowed to install subfloor.
when you calculate material cost vs time, the panels make sense.
Small addition with kitchen, dinette and living room. +- 700 sq ft. Finished floor will be hardwood of sorts.
@hot_rod : I looked at the Roth panels, but am dubious about installing hardwood directly over Styrofoam. @BillyO , I don't know climate panel, but the uponor quiktrak uses 5/16, which I want to avoid. @Alan (California Radiant) Forbes , I sent a request for info to Ecowarm.
Thanks all for your help, we'll see....0 -
its all a matter of choice and what you think your time is worth.0
I'm not sure why the "disagree" tab is anonymous now, but if someone's going to call me a liar they could at least have the gall to speak up and have an adult discussion about it.0
They may have disagreed with you, but the most likely explanation I've seen for the disagree button being pressed is because it sits under your thumb if you're a right handed person scrolling this site on a mobile browser. I've inadvertantly pressed it many times.GroundUp said:I'm not sure why the "disagree" tab is anonymous now, but if someone's going to call me a liar they could at least have the gall to speak up and have an adult discussion about it.
You can have it good, fast or cheap. Pick two0 -
I disagree with my wife all the time. If I were to call her a liar, she'd leave me. They're not the same.GroundUp said:I'm not sure why the "disagree" tab is anonymous now, but if someone's going to call me a liar they could at least have the gall to speak up and have an adult discussion about it.
Disagreeing means that you have a different opinion. To call a person a liar insinuates that you're trying to deceive someone and I don't think anyone thinks that of you.
When the "disagreement" is to a comment solely stating what I can do, that is calling me a liar.
Nothing on the reactions panel is anonymous, including Disagree. User icons appear under the post and you can hover over them (click on mobile) to see the username. In this case, @GroundUp, @BillyO disagreed with your post and then wrote, "It's all a matter of choice and what you think your time is worth." It's just a difference of opinion and he's not calling you a liar.
Now let's get back to talking about radiant panel choices. Thanks.President
HeatingHelp.com0 -
Maybe that’s just for you, being an admin. I don’t see icons when someone disagrees.Erin Holohan Haskell said:Nothing on the reactions panel is anonymous, including Disagree. User icons appear under the post and you can hover over them (click on mobile) to see the username. In this case, @GroundUp, @BillyO disagreed with your post and then wrote, "It's all a matter of choice and what you think your time is worth." It's just a difference of opinion and he's not calling you a liar.
Sorry for the misunderstanding here. I see what you mean about the Disagree reaction and we're going to troubleshoot. Thanks.
President
HeatingHelp.com0 -
really now?0
what problems do people have with Warmboard? I have used it in a few projects with great results. Not cheap ... yes .. but it's not hard to install after some thought and it makes a solid floor0
