RIP buderus st150
hpap
hpap Member Posts: 17
Installed Nov 2001, noticed discoloration yesterday, opened service hatch this morning and found a mess
  • hpap
    Now here's a interesting happening I'd thought to share here.
    I first noticed the discoloration in the master bedroom bathroom on hot side of sinks and tub, but nothing in others bathroom's or kitchen.
    The master bedroom was addition circa 2004 and I used aqua pex for the project. The rest of house is plumbed in copper, house built in 2000.
    Why no discoloration from copper supplied sinks ??
    Thanks
    HVACNUT Member Posts: 7,296
    What's your water quality?
    That's why the access cover and anoid rod are there. Was the tank inspected/cleaned at least bi annually?
    19 years isn't too bad, and it's not dead. No hole in the HX?
  • hpap
    Started life for 5 years with South Jersey pinelands acid water
    Then city water came in
    I'll be honest
    It's first time I had open
    Next one will get better attention
  • hpap
    No hole in exchanger
    But 19 years is a good run
  • TAG
    TAG Member Posts: 799
    Mine looks like a huge diving bell on three legs -- very heavy .. put them in around 94. One failed a few years ago the other is still going. I replaced it with the Buderus SS unit -- has the proper well for the sensor
  • hpap
    Install of the new st2oo complete
    A new old stock st200
    I bought it back in 2005 to replace the st150 for better capacity for a whirlpool tub, never got Around to it lol.
    Completion celebrated appropriately with a rauchbier also from Germany
    Ok, a few rauchbier s !!
    I think the control card for the electronic anode rod failed, I turned the top around so I can monitor the green light.
    I think you're the poster boy for Pro Press.
    hpap
    mattmia2 Member Posts: 15,944
    The electronic anode could be doing its job and that is just iron and other minerals from the water. Might be fine for another decade or 2 with a good cleaning.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,404
    Running at a high temperature more mineral come out of solution .. If not leaking I would just flush it out
    MikeAmann
  • hpap
    The thermo glaze is all but gone in the tank
    Only glaze I found was outside the gasket on tank access cover
    I ordered extra anode rod and gasket s
    I LL def keep watch on it
    I'm getting to old for another change in 20 years lol
  • Henry
    Henry Member Posts: 998
    Does anybody read the instructions for hot water tanks? You have to flush the tank once a year. I discussed HWT failures with my friend who is a technical director for a a tank manufacturer due to insurance companies requiring tank replacement after 10 years. A hot water tank whether electric, gas or indirect depending on water quality will last over 20 years. My previous tank lasted from 1985 to 2014. I have now a HTP S/S modulating gas HWT that will outlast me and saves me over $300 in gas each year.
    hpap
  • hpap
    Hi everyone
    Checked new st 200 today, anode rod gone after 2 1/2 years, replaced, washed tank out, now anode monitor flashing red
    hot_rod Member Posts: 26,998
    That Buderus was a nice tank with the large handhole. You could point a pressure washer inside them.
    I suspect many never get opened and flushed.
    MikeAmann
  • hpap
    The ST would probably last "forever" if maintained every 2 years.
    The hand hole as on a commercial boiler makes it easy.
     Now to sort out why red light on anode monitor is flashing
  • TAG
    How does the Anode monitor work?
    Since this initial post my the second Buderus tank failed .... not bad for 28 years. Replaced with another of the SS tanks -- wish they had a temp gauge like the old ones.
  • hpap
    Good day all
    St200 follow up
    on 2 nd anode rod check up in 5 years, found interior rusting already.
    Anode good condition
    Looks like rust is taking over :(
    City water, 3 grains water hardness, maintaining 125f water.
    Should I wash rust out with CLR perhaps ?
    24213cc0-2853-4721-90bd-bf9436bbd9d6.jpg IMG_20241228_111403551.jpg IMG_20241228_110948709.jpg
    removing the rust will just prepare the surface for more rust. why not put a powered anode in it?
    jesmed1
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,033
    Hi, That anode is not working correctly. It looks passivated to me. There should be an even, light gray, pitted surface… not as worn as the one pictured. 😏
    Yours, Larry
  • TAG
    Interesting … not in a good way.
    The new Buderus/ Bosh tanks are a fraction of the weight of the old … something not as thick.
    My last two projects have use Viessman boilers with matching SS tanks
