reverse supply, return on indirect hwh
jerryb46
Member Posts: 60
any difference switching supply return on a indirect HWH. What problems could it cause?
Page 6
https://www.caleffi.com/sites/default/files/coll_attach_file/idronics_17_na.pdf
You want storage tank stratification for best and most efficient use. You also get more hot water with less energy.
@hot_rod can explain it much better.There was an error rendering this rich post.
It would depend on the water heater.
A coil type indirect if they were reversed may have some/ little performance issues. At one point HTP on their Contender WH had the install diagram listed one way and the photo in the same book listed the opposite.
With a tank in tank set up there may be more of an issue.
Why do you ask? Was your indirect piped "backwards"
loss of capacity0
- 123 Chimneys & Flues
