thread pitch question
Depends on the material.
I'm assuming you are asking about brass or chrome plated brass fine thread on tubular pipe sizes.
Some plastics have a different pipe thread on there tailpieces.
Curious. Why do you want to know?0 -
yes,brass. Trying to figure what thread pitch it is. I think its 1-1/4-27 but its not ever listed in descriptions and nowhere else on the web...0
A thread pitch gauge would give you an answer. I don't think it is the same thread as a 1-1/4 fine thread bolt 1-1/4- 18?Bob "hot rod" Rohr
A long time ago I tried to find out too. I don't recall why.daleice said:yes,brass. Trying to figure what thread pitch it is. I think its 1-1/4-27 but its not ever listed in descriptions and nowhere else on the web...
I remember the only thread chart I could find (and still today) is that of the common pipe thread.
I'm curious as to why you want to know. Are you planning on threading with this type of thread yourself?0 -
Can't answer your specific question, but if you don't have a thread pitch gauge but do have an assortment of fine thread pitch taps, you can use those just as you would use a thread pitch gauge.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
1 1/4" NPT has 11 1/2 TPR, and I think an 1 1/4" slip nut will screw onto an 1 1/4" nipple perfct so it may be 11 1/20
I get 27 tpi, 1.25 ODBob "hot rod" Rohr
What are those fancy numbers on your caliper, where's the vernier scale...0
I have a few analog calipers, I like these digital to measure and convert metric parts quickly, with the push of a button🔩Bob "hot rod" Rohr
Living the hydronic dream1 -
Happy somebody invented screw idea but variations are cuckoo.
During lockdown I played with ballpoint pens. There are at least two varieties of Cross type refills. NOT interchangeable.0 -
oh the tail piece thought you meant the slip fittings.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
