Water Heater Connector
Good Evening
Thanks again for past help on my hydronic heating design. Hope to order all materials shortly.
Have a quick question on connecting my new RHEEM Hybrid water heater. I had hoped to use the Uponor flex connectors, but they are a special order in my area and I cannot wait.
I was wondering what the pros thought of the Brass Craft Procoat Stainless Steel Water Heater Connector SWB00-24N.
I need FIP to FIP connections and looking for something with a true 3/4" ID to not create a bottleneck in my system (I have Uponor tube everywhere else and have taken an effort to ensure no significant flow restrictions in system). I can get these fairly quickly online (I am in Canada, so online sources are limited) , but have not heard of them and do not know their quality.
If these are not a recommended connector, can the pros throw some recommended brands my way.
Many thanks
Sean
Many thanks
Sean
Sean Wiens
That is a good brand and should work fine. There is always a bit of pressure drop in a corrugated tube.
Maybe look at the braided stainless type, I think they flow a bit better.Bob "hot rod" Rohr
Living the hydronic dream1 -
I don't know what your story is with codes, inspections etc but Uponor allows direct connection of pex to non-atmospheric water heaters like power vented and hybrid. As long as the pex isn't near something hot like a drafthood.
So that would mean some threaded npt to propex adapters and you're done basically.
page 63 in the pdfSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Watts, Fluidmaster and a bunch of others offer braided stainless connectors, with various connection options. Here is a Fluid master example.SENWiEco said:
I think by code you are supposed to have a union connections? Does Uponor hav a fitting like that? I have seen regular Pex barb Union adapters, must be expansion versions also.Bob "hot rod" Rohr
If it was me and I needed to have unions and something between the heater and the pex to comply with code, I would use copper for that section. Throw your valves, unions etc all in the copper and then adapt to pex.
Previously I liked using a brass coupler and a male copper adapter because it seemed stronger than female copper adapters, but the recent batch of male copper adapters I got kind of.......sucked. Terrible threads but I made them work.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 50 Industry Classes
