By design hot water temp fluctuations
STEAM DOCTOR
STEAM DOCTOR Member Posts: 2,502
Hi. Received call from potential customer. He is building house from scratch. He wants different hot water temps, different days of the week (don't ask why, long discussion). Is such a thing possible? Indirect with two auqastats controlled by timer???? Any thoughts or ideas would be greatly appreciated. FWIW, he is not looking for anything tankless. Its basically a weekday, weekend thing.
  • ratio
    ratio Member Posts: 4,174
    A T775 with a schedule to set the temp back would do it.
  • STEAM DOCTOR
    Thank you @ratio. Will give a look. New world for me.
    hot_rod Member Posts: 26,484
    A motorized mixing valve? Maintain tank at 140F plus for legionella protection, motor valve to desired temperature.
  • STEAM DOCTOR
    @hot_rod. Thanks for the suggestion. I am looking for something programmable. To allow for different temps on weekdays and weekends. Not sure if zone valve would accomplish that. My ears are open. Thanks.
    It's probably overkill but the Caleffi Legiomix allows you to program in a high temperature mode for legionella protection.
    It watches both supply and reciurc return for assurance, somehow you would need to use both sensors.
    Does the system have recirculation?
    https://www.caleffi.com/sites/default/files/file/h0002997-05_na.pdf
  • STEAM DOCTOR
    Thanks Hot Rod. Will take a look. System doesn't exist yet. They are building house from scratch.
  • STEAM DOCTOR
    Don't have any details or plans. I am assuming they are open minded.
    Without knowing his intent, it's hard to say which option would be best, but you have a number of workable options. Does he want a quick switch, or could the tank be depleted down to the lower temperature?
    If you do it with valves, they all need to be low lead of course.
  • STEAM DOCTOR
    I think that he would prefer something that adjusts tank temperature
    EdTheHeaterMan Member Posts: 11,529
    edited May 2020
    L4081 and L6081 controls have 2 sets of contacts with one sensing bulb. This is really old school but with the proper wiring design you could change the temperature with a switch upon arrival on the weekend, then return the switch to low temp on Monday..
    For automatic control, an Intermatic timer could be implemented.
