BMS for small buildings recommendations
madapan
Member Posts: 6
Has anyone found a good BMS system tailored to small buildings?
What exactly are you trying to control?
What is your background?
There are few pre-canned options out there. Most larger systems are custom programmed."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I've built several with off the shelf components. Depends on how many zones, type of system, water, steam, VAVs, rooftops, etc.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 116 Geothermal
- 15.8K Strictly Steam
