At It Again
New England SteamWorks
Member Posts: 1,505
They built the house around this Big Boy. Sections have to be broken up in order to remove.
newenglandsteamworks.com
Replacing with a Weil McLain 380, about a quarter the size of the original...New England SteamWorks
newenglandsteamworks.com2 -
Yeah, I don't like heavy stuff anymore......
Glad it's you.
Rick0 -
just look at the size of that gas supply
what a beastI just earned my GED and am looking for a apprenticeship with one of these steam gurus on this site!0 -
...And the size of the flue pipe (pipe-a-saurus).
@New England SteamWorks
How did you get things to be so clean?
There's no soot, no water with rust on the floor?
Nice!0 -
Did it leak or was fuel savings the motivation?0
Years of practice!New England SteamWorks
newenglandsteamworks.com0 -
Leak? Fat chance. Pristine inside. Also a 3-pass. Could easy have gone another 50 years. But unaffordable.New England SteamWorks
Day One in the can. Happy Hour!
Look ma, no header! I was just running the velocity numbers on the 380 a couple days ago ( I hope to use 2 of them at my church) and with those big 4 inch tappings, it quite unlikely any water is getting up out of the boiler. Even just a single tapping will have your exit velocity down around 24 ft/sec... still well under the carryover velocity of 32 ft/sec for 4 inch pipe. I have the two laid out using just single 4 inch riser over to a common header that drips into the common return..... Slant Fin style. I still kept the system supply past the two risers.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Actually, it does have a 4" header. The original one up in the ceiling. Off of that header are the 3 supplies.
We thought about doing our standard drop header, then connecting to the original header, but that seemed like overkill. Especially with all of the height we have, and the 4".New England SteamWorks
newenglandsteamworks.com1 -
It'll make more sense when we put the equalizer back.New England SteamWorks
Yes, I saw that up there, that looks more like a manifold than a header... the supplies are coming off everywhere.. on either side of the boiler supplies, in between, and the equalizer is on the opposite end. However, with the 2- 4 inch boiler risers, your velocity in the risers is only about 12 ft /sec...nice and low.To learn more about this professional, click here to visit their ad in Find A Contractor.0
So tiny!! What's the EDR of this boiler? Oh and I see it's not on any blocks! Is that your typical install pattern?
I'm trying to understand when and why people put so many on blocks (mine is on blocks)NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0 -
EDR is 867. We don’t use blocks on steam as we like to have all the height we can get for dry steam, and to aide in A or B dimensions.New England SteamWorks
Yes I like that thinking!! And I guess it's not so tiny!NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
Day Two in the can. Have a good weekend everyone!
It’s a wrap!New England SteamWorks
Wow! Fantastic!
@New England SteamWorks. Beautiful install as alway.0
It's impressive how quickly and smoothly you complete these projects. What size crew was working on this one?1950's Bryant boiler in a 1-pipe steam system at 7,000 ft in northern NM, where basements are rare.0
The first two days we had two. But illness struck over the weekend, so just one on last day.New England SteamWorks
So do we!New England SteamWorks
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
