L
  • STEVEusaPA
    If you just had it installed, why isn’t the installer fixing it? Or did you install it yourself?
  • JPL941
    JPL941 Member Posts: 51
    edited August 2023
    Hello
  • GroundUp
    GroundUp Member Posts: 2,513
    I may be nuts, but I seem to recall someone saying that 1/2" copper pipe can be soldered inside that fitting to avoid the goofy flat threads and leak potential
    hot_rod Member Posts: 27,446
    Try an EPDM gasket, those fiber washers can be tough to seal.
    A water meter gasket, or hose washer may be the correct size
    With fiber washers, both surfaces need to be flat and clean. Wet the washer before you put it together for best results. Or a thin coat of pipe dope.
