Spirovent drip
frankjc
Member Posts: 38
Hello. I have noticed that the Spirovent micro bubble resorber has a slight drip. What could be causing this to happen?
Thanks.
Thanks.
Groundup
If you have many air eliminators of any kind that leak often maybe you need to address system water quality. Water in all types of boiler systems should be checked.0 -
No, it's a Spirovent issue and nothing further. None of the other air eliminators dribble, just the Spiro units. While I fully agree that water treatment can and does play a big role in system longevity, it's irrelevant to the Spirovent problem in 100% of the cases I've handled.bob eck said:Groundup
Heh, ironically enough I just got home from a job that was installed 7 years ago with a 1" swt Spiro. Guess what was leaking! Water tested out perfectly, just another weepy needle. Honeywell SuperVent in the detached garage installed the same year with the same fluid was clean as a whistle.0
- 15.8K Strictly Steam
