Spirovent drip
frankjc
frankjc Member Posts: 38
Hello. I have noticed that the Spirovent micro bubble resorber has a slight drip. What could be causing this to happen?
Thanks.
  • kcopp
    kcopp Member Posts: 4,570
    Probably some dirt/ scale got under the float in the unit. Now it does not seal off super well....
    Intplm.
  • Grallert
    Grallert Member Posts: 969
    When you replace the head, pull the wire strainer thing out and inspect it as well. I've found they sometimes come apart.
    kcopp
  • GroundUp
    GroundUp Member Posts: 2,360
    This is precisely why I refuse to use Spirovents. Seems every darn one of them leaks by after a year or two.
    bob eckSuperTechHVACNUT
  • bob eck
    bob eck Member Posts: 930
    Groundup
    If you have many air eliminators of any kind that leak often maybe you need to address system water quality. Water in all types of boiler systems should be checked.
  • GroundUp
    bob eck said:
    Groundup
    No, it's a Spirovent issue and nothing further. None of the other air eliminators dribble, just the Spiro units. While I fully agree that water treatment can and does play a big role in system longevity, it's irrelevant to the Spirovent problem in 100% of the cases I've handled.
  • unclejohn
    unclejohn Member Posts: 1,833
    I probably have over 25 SV and never had a leak.
    Solid_Fuel_Man
  • GroundUp
    edited April 2020
    Heh, ironically enough I just got home from a job that was installed 7 years ago with a 1" swt Spiro. Guess what was leaking! Water tested out perfectly, just another weepy needle. Honeywell SuperVent in the detached garage installed the same year with the same fluid was clean as a whistle.
    hot_rod Member Posts: 25,148
    Probably a spec of crud under the seat, it can happen with any brand. Some brands are easier to disassemble and clean.
    Solid_Fuel_Manbob eck
