Summerizing my boiler
Ozmat
Ozmat Member Posts: 18
edited April 2020 in THE MAIN WALL
Do I drain the boiler or leave it full of water when not in use for the next six months?
  • STEVEusaPA
    No, don't drain.
  • Grallert
    Grallert Member Posts: 969
    I have two big boilers. Essentially the same things you might find in a big residence but really big. At the end of the heating season I fill them up to the very top and fire them up to boiling to remove the O2 and close the king valves.
  • Intplm.
    Intplm. Member Posts: 2,675
    Its called a wet lay up. Keep water in them till the next heating season.
    And do what is said ^^^^^^^above^^^^^^^
  • bburd
    bburd Member Posts: 1,173
    And don’t forget to drain it down to normal level on the gauge glass when you fire up in the fall!
    Bburd
  • Ozmat
    Thanks for the information. Last season I added 8-way boiler water treatment to the boiler. What are the thoughts on additives for rust and corrosion control?
  • Intplm.
    Ive used them commercially with very good results. Just be very good about following the manufacturers suggestions.
    Grallert
