Boiler running too long
bboogert
Member Posts: 3
What would cause a one-pipe steam boiler to keep running long after all the radiator vents have closed? This is a recent change in behavior. I can hear the sound of boiling water echoing through the cast iron and lots of dripping inside the whole system. Clogged pigtail?
-1
Need to know what pressure is being reached. Because... a third possibility is that you have a steam leak.Br. Jamie, osb
If your pigtail comes out horizontally on the side of the boiler, by all means, thoroughly clean it. With the loop going down from the horizontal connection just makes the probability of clogging worse. It seems many modern boilers are set up that way. My boiler has the Pressuretrol and gauge connected to the upper gauge glass connection. The two attachments, if readable, show the difference in arrangement.
https://us.v-cdn.net/5021738/uploads/editor/d0/0b7nh6tw4hah.jpg
When you click on the link, the image may be too large, just reduce the size and you can see the arrangement.0
Thank you for these suggestions. I will investigate, but quick question about the pigtail...is there a special silicone tape for steam connections, or dope, or anything I should use when putting it back together?0
I always use PTFE tape between brass and cast iron because it's a good dielectric.Just another DIYer | King of Prussia, PA
Thank yo7 all for your suggestions. Sadly, this project will go on hold until the plague passes. The system may not be running optimally right now, but it’s working and I don’t want to put anybody at risk to come fix something that I $&# up. I’ll get back to you when it’s safe aga8n.0
- 50 Industry Classes
