New primary control does not shutdown boiler
Rob48xx
Member Posts: 26
I posted this previously under new boiler but didnt want to confuse or complicate a previous post. I replaced the primary control unit that seemed to be faulty. The new unit is the Honeywell R8184G4009 which is the only one i can find right now especially with everything on lock down.
I have a aquastat control and wheni replace rhe primary control and fire everything up the boiler never shuts down almost like its not being told too and keep heating well above rhe high limit. When i turn down the hi limit manually it shuts off but that is the only time. I jumped the TT since the tstats terminate to the aquastat, though the old unit didnt need this. I get the sense i am missing an installation step somewhere.
Any ideas
Any ideas
Well it's not the primary. The old one didn't have TT terminals. It was internal with intermittent (constant) ignition.
What model aquastat do you have?0 -
Will take a look to confirm again the cabling0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
