Navien combi domes hot water issue
danitheplumber
Member Posts: 98
Had Navien combi boiler firing up to 210 when a call for domestic hot water was called for but for some reason the domestic cold water was steam hot and domestic hot side ice cold. Anyone seen or know what would cause this? No error code came up...
Lack of flow.Bob Boan
Ya I assume it's never been flushed...0
I'm referring to the hydronic side.Bob Boan
Also, check the inlet screen on the cold.Bob Boan
It's a domestic hot water issue. The only thing is it seems hot water is going into cold inlet and cold water into hot outlet side so maybe 3 way valve issue0
Hi, I’ve met heaters that were plumbed in backwards. You might want to trace down flow to double check the piping. You can’t assume anything. I was once the sixth plumber to look at a troubled job. Turned out there was insulation on the cold and not the hot.
Yours, Larry0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
