What Happened To Indirect Hot Water Heater Quality?
JacquesD23
Member Posts: 11
If you look at the indirect brands from 20+ years ago. They made tanks that are still around today. But now a days I wont even use the previous "Best" brands like Amtrol, Triangle Tube, Mega Store, etc. I have had multiple cases where we replaced a 30 year old Amtrol with the new model, and we end up replacing it under warranty 3 times in under 6 years. Why did these companies forget how to make tanks that last?
The only model I still use is Superstore SSUs and the Vaughn Stone line. Which so far I have had decent luck with.
I took a 30 year old Amtrol hot water heater out of a customers house about 7 years ago. In the previous 6 years he has gone through 3 of them, and now we said forget the warranty and changed to a Superstore.0
I have had the same thing happen with the new Triangle Tube Phase 3s and Mega Stores. The 20+ year old ones did not have warranty failures that were this common even in the same water quality. They are failing at the piping connection seems on these new ones very consistently. And I have verified with my supply houses that it is happening to everyone that uses those formerly top quality brands.0
- 50 Industry Classes
