Leaking Valve
JayLobo
Member Posts: 8
Hi everyone I have a weird question I have a steam boiler and fill up the water once the water light comes on or sometimes before . Any way the valve leaks from the handle sometimes.But can this also drip into the boiler ? For some reason my boiler has more water then it did before I know I shutoff the valve.
No, the drip from the handle can't get into the boiler. However... a drip from the handle (which can usually be cured by tightening the packing) may also indicate that the valve is... tired. If it's a globe valve, you may be able to refinish the seat and replace the washer. If it's a gate or a ball, it could be leaking by -- and the only sure cure is replacement.Br. Jamie, osb
Yes it a bad valve I dumped some water waited a few hours went and Checked my sight glass and the level was up again0
No hot water coil.0
@jaylobo
Yes you need a new valve. If you know how to cut and sweat pipe you could do it (i am assuming it's copper pipe)
Or you can get a plumber or your service dept.
There's always "shark bite" valves which can be put into a copper line without soldering.
I don't like them but they would get you through the winter at least. You could cut one of those in and leave your existing valve in place. Lowe's and HD have them they are all the rage now1 -
I'm lucking who ever installed used a threaded valve . I hope its easy to remove . If not I just call the plumber and have them also install a backup shut off I have not sweated a pipe in a while .0
The only positive is my boiler has never been so clean
I have to keep draining some water every few hours. 0 -
Which valve should I buy with or without bleeder?0
That looks to be a gate valve....you do not want another one.
They are notorious for failing to provide 100% shut off.
A ball valve would be the better choice there, but they may be too long and the handle might not be able to swing/rotate as needed.
IIWM, I would go for a good quality globe valve that is close in length to what you have there. Then no handle problems.1 -
@JayLobo
I would replace it with a ball valve if you have the room. Or use a globe valve. Measure the length of you old valve and try and find one the same length.
There are union fittings on both sides of the backflow preventer so you can remove that easily.
If the new valve is longer or shorter you can adjust that with the length of the threaded nipples on either side. Use brass nipples.
And once you take the backflow preventer out you will have to put new gaskets in the union fittings.
Pretty easy if you have the right stuff0 -
@JayLobo
Glad you got it fixed. Did the boiler stop filling? Was the old valve a Globe valve with a bad washer or a gate valve?0
