Steam heat radiator noise
coolfx35
Member Posts: 77
This has been bothering me for a while, I finally got a chance to record it and put it on youtube.
https://www.youtube.com/watch?v=dPyu8NK9ME8
When the heat comes on for about 15 minutes, I hear the air noise and water boiling noise, this is in my master bedroom so often it wakes me up. What seems to be the issue and what's the solution? I have 4 radiators like that only one is doing it.
Thanks for your advice.
It sounds like air -- or steam -- is trying to get by some trapped water somewhere. Not enough to hammer.. check and make sure that the radiator inlet valve is really fully open, and that the heating element is pitched somewhat towards the inlet end.Br. Jamie, osb
i have changed the varivalve a few times... how do You know if a varivalve gone bad? when i shake it, should it make a noise?
When they leak steam ,
I would recommend switching to an slower float type radiator vent .. VariVents were design to use with a Heat Timer used in large buildings . They are very fast venting without a float shut off .. You may have other problems , lack of pipe insulation and bad main ventsThere was an error rendering this rich post.
The valve to which I am referring is the inlet valve, not the vent. Granted it may not be the correct vent (it isn't) but that isn't the cause of the noise you are hearing.Br. Jamie, osb
inlet valve were fully opened, I actually just close it half way. Let's see if anything changes.0
Inlet valve on one pipe steam -- like yours -- needs to be all the way open or it will trap condensate in the radiator.Br. Jamie, osb
Everything Jamie has said, ...as usual! If your inlet valve is fully open and you have some pitch to the radiator toward the inlet side and you are still experiencing the issue then maybe you are getting wet steam to the radiator. Is the radiator fully hot all the way across when you are getting this noise or is it still in the process of filling with steam? If fully hot then perhaps you just really want to slow down the venting rate at the radiator, particularly if other radiators in your house at the same time are not fully hot.0
Get rid of that Varivalve vent and replace it with a Vent-Rite or Maid_O_Mist. Those varivalves are so aggressive, even at lower settings that they are noisy and more often than not they spit water and sound like gurgling. If changing the vent still gives you the problem, then we can look elsewhere but replacing that vent is the first step in diagnosing the problem. I suspect it will fix the problem.0
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
