Can't purge the air out of the boiler!
Use a 3/4" Black Iron coupling.0
I know this air problem is new, but if you’re going to drain the system to make improvements, why not go all in?
Install a good air separator on the supply, move the pump to the supply, pump away from the expansion tank and install a better backflow preventor and fill valve. Caleffi’s is hard to beat.Steve Minnich0
- 120 Geothermal
