anti freeze test
Will an automotive anti freeze tester work on a hydronic system to check % of concentration. If not can someone recommend one. Thanks
    hot_rod Member Posts: 26,565
    There are testers for PG type automotive fluid, see if you have that type
    HVACNUT Member Posts: 7,216
    Get a refractometer for propylene (hopefully) glycol.
  • BillyFris
    BillyFris Member Posts: 7
    Utility PG is in the system
    EBEBRATT-Ed Member Posts: 19,502
    @BillyFris
    a refractometer is the only tool i know of.
  • BillyFris
    Advanced Auto has for PG anti freeze and Amazon has refractometers. Thanks for the help
  • HomerJSmith
    HomerJSmith Member Posts: 2,704
    Buy a refractometer from DHGate.com, Ebay.com or Amazon.com. They are cheap, really cheap and would do the job better than any auto antifreeze tester.
    depending on how often you plan on using it, and the quality there is a wide price range for refractometers.
    80 bucks buys a good quality name brand meter.
    Floating ball type are common at automotive suppliers.
