anti freeze test
BillyFris
Will an automotive anti freeze tester work on a hydronic system to check % of concentration. If not can someone recommend one. Thanks
There are testers for PG type automotive fluid, see if you have that typeBob "hot rod" Rohr
Living the hydronic dream0 -
Get a refractometer for propylene (hopefully) glycol.0
Utility PG is in the system0
Advanced Auto has for PG anti freeze and Amazon has refractometers. Thanks for the help0
Buy a refractometer from DHGate.com, Ebay.com or Amazon.com. They are cheap, really cheap and would do the job better than any auto antifreeze tester.0
depending on how often you plan on using it, and the quality there is a wide price range for refractometers.
80 bucks buys a good quality name brand meter.
Floating ball type are common at automotive suppliers.Bob "hot rod" Rohr
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
