Cleaning a plugged aluminum block boiler
HydroBob
Member Posts: 1
Any suggestions on how to clean a plugged ECR UB-200 aluminum block? Spraying mineral oil 7 times did not work well. Utica said not to fire boiler with mineral oil on the block.
> @EBEBRATT-Ed said:
> Bosch/Buderus says to use mineral oil to clean their HXs.
> I thought you were supposed to let it burn off
Now I have to look that up. Wasn’t aware!1 -
I thought you were supposed to let it burn offhttps://www.youtube.com/watch?v=fZTu37sEELg&list=PLq4NGiyqj85YbH1rMZ1lfRFwEj4kkmFxb&index=5&t=3s
The mineral oil part starts at about 3 minutes in.
Sorry to get off topic.
Two btu per sq ft for degree difference for a slab1 -
> @Alan (California Radiant) Forbes said:
> (Quote)
Always willing to learn!1 -
Yes, thank you for posting that information. I don't come across very many aluminium Buderus boilers. I wouldn't have thought that mineral oil would aid in cleaning the heat exchanger. Learning surprising information like that is why I come here, and a big part of what makes this site great.0
Apologies are in order. You learn something new every day.
I still stand on 2 and 3 though.0 -
I believe fernox makes a cleaner for aluminum boilers.0
Where I previously worked I installed a bunch of these. Never had to clean one though but I herd about it. Their nice boilers if you don't mind aluminum HXs.
@HydroBob
How does Utica recommend cleaning it??0 -
Axiom has some good stuff... wear a respirator though.
FW Webb is now carrying it.
http://axiomind.sasktelwebhosting.com/pdf/AXI-THERM CLEAN_F9-AL.pdf0 -
Insist with mineral oil, it doesn't make sense for this solution not to work.0
@EBEBRATT-Ed With a water hose through the hole where the igniter was.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 969 Plumbing
- 385 Solar
