"Power Flame Burner " C-2 G 15; for sale
DKD228
Member Posts: 1
"Power Flame" High Output Gas Conversion Burner Unit , - $450 obo; (Millville, NJ)
serial # starts with 0792 that's July 19920
@DKD228 , what model boiler was it on?All Steamed Up, Inc.
Consulting0 -
It has the scotch marine style blast tube on it, usually used in a boiler with some back pressure in the fire box. I think it's fixed fire don't see any linkage from gas valve to air damper0
straight Oil ..??
GLWS
The 'G' in the model number implies this is a gas only burner (C2-G-15). The '15' means it has a 1.5" gas train, or at least the orifice tee is 1.5". The C2 is the frame, C1 for the smallest, C5 used to be the largest, not sure that is still the case.0
- 123 Chimneys & Flues
