"Power Flame Burner " C-2 G 15; for sale
DKD228
DKD228 Member Posts: 1
edited January 2020 in Buy, Sell, Barter
"Power Flame" High Output Gas Conversion Burner Unit , - $450 obo; (Millville, NJ)
    EBEBRATT-Ed Member Posts: 19,891
    serial # starts with 0792 that's July 1992
    Steamhead Member Posts: 18,324
    edited January 2020
    @DKD228 , what model boiler was it on?
    Consulting
    It has the scotch marine style blast tube on it, usually used in a boiler with some back pressure in the fire box. I think it's fixed fire don't see any linkage from gas valve to air damper
  • B_Sloane
    B_Sloane Member Posts: 56
    straight Oil ..??
    GLWS :)
  • ScottSecor
    ScottSecor Member Posts: 1,023
    The 'G' in the model number implies this is a gas only burner (C2-G-15). The '15' means it has a 1.5" gas train, or at least the orifice tee is 1.5". The C2 is the frame, C1 for the smallest, C5 used to be the largest, not sure that is still the case.
