Experience with using Drayton Wiser thermostats for TRVs?
jsavage
Member Posts: 44
I came across the Drayton Wiser connected controller for TRVs online. It seems to be a product that’s available in the UK and is compatible with the Danfoss RA series valves. Does anyone have experience with this system?
I was thinking of trying to order one from the UK to see how it works.
Here’s their website:
https://wiser.draytoncontrols.co.uk/radiator-thermostat
Here’s the amazon UK link:
https://www.amazon.co.uk/dp/B075GRPZQ1/ref=sspa_mw_detail_1?psc=1&pd_rd_i=B075GRPZQ1&pd_rd_w=EcFOX&pf_rd_p=58d8be92-db2b-4615-be3c-c54aa469c981&pd_rd_wg=zLzaQ&pf_rd_r=2JSCTSYN35DAEQTQ19YH&pd_rd_r=0fd2f5a6-3a68-41cc-915b-f275f73af4eb&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzMExBTlJKTThSSUs1JmVuY3J5cHRlZElkPUEwMTkyNjA4MUpXMTEzUEpJUjNJSCZlbmNyeXB0ZWRBZElkPUEwNzQ3OTAyMkxIWjdZM1pKWllBQSZ3aWRnZXROYW1lPXNwX3Bob25lX2RldGFpbF90aGVtYXRpYyZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Homeowner from Providence, RI
Home b. 1897, one-pipe steam with a indirect gravity hot air system using Gold's pin radiators.
Are you controlling a one-pipe, or two-pipe system?
I would think that it would be difficult to use a hot water control on any sort of steam system, especially one which relies on air vent control.—NBC0 -
TRV are best suited to modulating boilers with constant pressure pumps with a end loop bypass.
TRV’s and modulating boilers I believe are mandated in Europe on radiant systems.0
- 50 Industry Classes
