Armstrong Astro 230CI water pump loud
One of my Armstrong Astro water pumps is suddenly making a loud noise compared to the other 5 pumps what can I do to fix that issue? See attached pictures
    hot_rod Member Posts: 27,410
    Carefully loosen that large screw and see if any air vents out. Air trapped in the circulator is one common noise.
    If it is more of a squeal, could be the bearing is fried, the motor will need to be replaced. Is it circulating the water ok?
    If a large pocket of air traps it will stop flowing and often the motor gets very hot to the touch. This condition is when the bearings can be compromised.
