Hot water zone control valve
hubbell
hubbell Member Posts: 1
When a zone control valve closes is it normal for some water to get by and keep the baseboard warm?
  • STEVEusaPA
    No. Might be hanging up.
    hot_rod Member Posts: 26,532
    And sometimes you can get some reverse flow. Zone valves on the return of a multi valved systems.
    Or too large of a circulator for the valves to close against.
    If it has worked in the past, no other changes, I'd suspect crud in the seat or a stuck actuator.
    @STEVEusaPA
