Hot water zone control valve
hubbell
Member Posts: 1
When a zone control valve closes is it normal for some water to get by and keep the baseboard warm?
No. Might be hanging up.
And sometimes you can get some reverse flow. Zone valves on the return of a multi valved systems.
Or too large of a circulator for the valves to close against.
If it has worked in the past, no other changes, I'd suspect crud in the seat or a stuck actuator.
@STEVEusaPABob "hot rod" Rohr
Living the hydronic dream0
- 129 Chimneys & Flues
- 122 Geothermal
