One zone calling but floor cold
jpavano
jpavano Member Posts: 3
Hi I’m new here-just moved into house with radiant heat (tekmar computer, watts manifolds and actuators etc.). Question 1: have one bathroom that is calling for heat but floor is cold. The watts actuator indicator shows open or on ( not red) the hose going into the manifold is warm, but the floor is cold. Could actuator be stuck?
Question 2: I bought some spare watts actuators-the ones installed are 2.5 watts. The supply house keeps shipping me the same actuator but they are 1.6 watts. Will they work?
Thanks!!
  • STEVEusaPA
    Could simply be air bound.
  • jpavano
    Issues w two adjoining rooms. One calling but no heat. Other not calling but warm.
    The cold room in and out lines are warm. I checked and changed the actuator today too.
  • jpavano
    How do I bleed that one loop?
  • rick in Alaska
    rick in Alaska Member Posts: 1,513
    We would need to see a picture of your setup showing the manifold and boiler piping. Take it from as far back as you can so we can see as much in one picture as possible.
    Rick
